0 Members and 1 Guest are viewing this topic. Read 1779 times.
I think mressequie is envisoning a passive mute box. This could be constructed with quality components. Most specifically the switch to disconnect the channels would need to be silent so it could be switched and not make a noise itself. Make-before-break on off switch?Hmm, a quick google did not yield what I was thinking of. I'm thinking a single toggle switch in a small box with in and out RCA connectors. The switch would be a 2 position, 4 poles, with high quality silver contacts which I would connect to each of the hot signal wires of the interconnects between preamp and amp.D'zat sound like what you had in mind, Michael?
