FS: Palmer Monicon Passive Monitor Controller
0 Members and 1 Guest are viewing this topic. Read 355 times.
Cacophonix
« on: 3 Jan 2023, 12:50 am »
Used it sparingly on my desktop to control the volume of my JBL 305/310S setup. Sounds very very transparent, and has no issues.
Moved onto a simpler setup, and don't have a need for it anymore.
Asking $75 + shipping (~$15 cont US)
Shipping will be from 75025. Local buyers welcome.
Details at : https://www.palmer-germany.com/en/products/studio-monitors-and-monitor-controllers/5193/monicon
Channels    1
Inputs    2
Input connectors    3.5 mm TRS, XLR
Input type    balanced/unbalanced (depending on TS/TRS connection)
Max. input level    20 dBu
Input impedance    (balanced) 10k Ohm(s), (unbalanced) 5k Ohm(s)
Outputs    2
Output connectors    3.5 mm TRS, XLR
Output type    balanced/unbalanced (depending on TS/TRS connection)
Max. output level    20 dBu
Output impedance    600 Ohm(s)
Frequency response    10 - 40000 Hz
Total Harmonic Distortion (THD)    0.001 %
Max. attenuation    (Attenuator + Mute) 112, (Attenuator) 85
Controls    attenuation, mono, mute
Cabinet material    sheet steel, wood
Cabinet surface    Powder coated
Width    164 mm
Height    62 mm
Depth    85 mm
Weight    0,75 kg
