SOLD: One pair Blue Jeans Cables RCA Interconnects 38+ ft
0 Members and 1 Guest are viewing this topic. Read 333 times.
pstrisik
  • Holding pattern in Audio Nirvana in the PNW!
================SOLD===============
I bought these in anticipation of moving subs into the room, away from the preamp. I never did, so these cables are unused. They are the same cables as their stereo cables (LC-1). The only difference is the color of the connector jackets. Can therefore be use either for subs or for stereo cables. Each is over 38ft.
New would be $190 plus shipping. Selling these for $125 with shipping anywhere in the U.S. included and the paypal fee covered (approx $25 I'm covering out of the price).
Here is their description of the cable:
https://www.bluejeanscable.com/store/subwoofer/LC1-design-notes.htm
And about the connectors:
Connectors are a critical part of any audio cable, because if the cable isn't well-joined to the connectors, or if the connectors don't make firm electrical contact with the jacks, it doesn't much matter how good the cable is. Our LC-1 cables are terminated with the Taversoe RCA plug, a high-quality RCA plug with an all-metal body and shell specifically designed for the perfect dimensions for use with LC-1. Its all-metal body, crimped tightly to the shield braid, completes the shielding assembly from cable end to cable end, to ensure that the cables do not become an entry point for noise. These plugs are gold-plated on all jack-contact surfaces, and employ a set of leaf-spring style grippers on the outer RCA ring which apply just the right amount of force to the jack to grip it firmly without over-tightening.
Thanks.......Pete
« Last Edit: 4 Jan 2023, 03:42 pm by pstrisik »
