Synergistic Research Galileo UEF Speaker Cables, SOLD SOLD SOLD
0 Members and 1 Guest are viewing this topic. Read 734 times.
mikeg1
Original owner and mint. Installed and moved only for Blue Fuse treatment upgrade. Galileo UEF 8ft pair with spades at both ends of each cable. Blue treatment found in SX ($800 value) and upgraded SX UEF tuning bullets. Essentially these are Galileo SX speaker cables. Shipping is a flat rate of $35 in USA.  Willing to ship worldwide.  Only PayPal friends and family accepted. See my 20 years of excellent audiogon feedback under mikeg.  Asking $5495 ($15,800 retail).  Please see my ad for the matching 1.5m XLR interconnects.
Galileo UEF Speaker Cables are made by hand in our California factory from (4) High Current Silver Matrix geometries, (1) 4th Generation Tricon Silver Matrix geometry, (3) Hand Made Pure Silver / Graphene AirString Geometries and (1) Hand Made Pure Tungsten AirString geometry. All 9 parallel geometries utilize our patent pending UEF Graphene Shielding for a total of 18 cables in a single pair of Galileo UEF speaker cables. For added clarity each individual geometry is separately sheathed to cancel cable resonance for clear effortless sound with natural decay and timbre.  When voicing these speaker cables we added a Tungsten AirString Geometry for the unique sound staging properties of tungsten as determined during a 6 month long double blind listening test conducted to find alternate conductors for audio cables.
As with Galileo UEF Interconnects, we engineered a complex Multi-Layer UEF Inductive Cell and coupled it to each cable’s 9 shields, 12 signal conductors and ground. The heart of Galileo UEF speaker cables’s performance is its UEF Inductive Cell made from Pure Silver Foils and Graphene with a dielectric made from Japanese Silk chosen for the warmth and layering silk delivered over traditional dielectric materials discovered during a series of double blind listening tests. For versatility and system compatibility Galileo UEF speaker cables can be run shielded with the ground plane connection attached to either a SR Ground Block, or with the included ground connector. Additionally they can be used without shielding for mono block amplifiers and speakers that perform their best when run with unshielded speaker cables. Simply connect the shield to ground or leave it disconnected. One advantage of our exclusive UEF Graphene Shielding is that it works whether the shield is connected to ground, or not.
To custom voice these speaker cables to your system you select between two bespoke UEF Tuning Modules voiced expressly for Galileo UEF. The Gold UEF Tuning Module imparts a warm and musical balance replete with maximum soundstage bloom or select the Silver UEF Tuning Module when your system sounds best with a more detailed and pin-point sound stage balance. A third option is to simply not attach either UEF Tuning Modules but the choice is yours to make based on the option that makes music in your system.
Lastly, these loudspeaker cables received the same conditioning process they developed for SR Blue Fuses and this increases their musicality as well as shortens their break-in time so you spend more time listening to music, not waiting for your cables to burn-in. And of course, SR hits each Galileo UEF interconnect with 1,000,000 volts of electricity on the big Tesla Coil with a new sweeping frequency pattern that dramatically improves how the signal propagates for the most efficient signal transfer.
"...This set replaced the Wireworld Platinum Eclipse 8 used between my Accuphase Pre-amp and amp. Right away you can tell something special has happened, as if you've sonic-ally climbed a hill and are now above the fog you used to be under. Much greater transparency allows fine details to emerge from a deep black backdrop. They are abundant in rich harmonics, as if all the instruments have been fleshed out and seem more real and three dimensional with a true to life, you-are -there experience that's somewhat lacking in the Wireworld. These are expensive cables but like climbing Mnt. Everest they're a once in a life-time experience that will increase and broaden your love for recorded music. My advise is just do it and be happy for a long time..."
REVIEWS:
Howard Kneller of SoundStage UltraSound (April 2019) wrote:
"...the Galileo SXes may well set a new high bar for audio-cable performance. Further, while at first glance their geometries are more similar to than different from those of the Galileo UEFs, the SXes considerably outperformed the older cables... I’m smitten with the sound of Synergistic Research’s Galileo SXes: breathtakingly lively, exciting, and dynamic, yet gorgeously rich, musical, and accurately full-bodied. They are definite contenders for the designation 'the state of the art'..."
Includes: box and 2 homemade 18 gauge silver with Teflon and carbon fiber jacket cables.  These are as good as the HDG cables that sell for $399 each.
« Last Edit: 6 Feb 2023, 02:04 pm by mikeg1 »
mikeg1
Bump for a price change.
mikeg1
