What's the teac AL700p's front panel made of?
0 Members and 1 Guest are viewing this topic. Read 1010 times.
franjy
« on: 16 Apr 2005, 04:05 pm »
Is it plastic? Plastic and metal? Hard to tell. Would like to paint it but need to know what it is I'm painting.
mcgsxr
« Reply #1 on: 16 Apr 2005, 06:11 pm »
Having painted it, I can attest that it is metal of some kind, a formed shape that fits onto the plastic shell - it is held on by a couple of screws on the side, under the top U shaped shell.
I used Truck Bed Liner on it, no primer, and it worked fine.
Not the prettiest finish I will admit, but I like the slightly textured look.
Good luck, post some pics!
