For sales zip 90042: tekton design Perfect Set 96db 8ohm
0 Members and 1 Guest are viewing this topic. Read 556 times.
bryan0101
zipcode location 90042
Asking 1500.
Here I have a pair of Tekton design Perfect Set.
Their patent tweeter+mid array system, with 12" woofer and front port, and spike footers.
It does not come with grill, it does have Cardas upgraded connectors in the back, and from the website ordering form, it should include:
"Upgrade to solid billet copper Cardas inputs (USA), mil-spec internal wiring, Mundorf or ClarityCap (depending upon real-time availability) within the tweeter section and an oversized Jantzen or Erse Sledgehammer inductor (depending upon real-time availability) within the woofer section.".
I got it from a local gentleman who were upgrading. This is my third system, being used exclusively with SET amp for certain music. It has been a success and I'm itching to test their other models.
There are 3-4 small blemishes on top from previous owner, possibly caused by putting something heavy on top to extract better imagining and tight bass (I had tempted to do the same as well even tho it sounds great on its own already.
Local pickup within Southern California 90042, I can also deliver within reasonable distance. You can text me anytime with the number listed on the first photo.
review:
https://6moons.com/audioreview_articles/tekton/
"Historically, the shortcomings of speakers teamed up with SET amplifiers were colorations in horn designs, lack of high-end extension with single drivers or the need to back-load them to deliver deep bass which usually led to very large cumbersome enclosures. The Tekton Design Perfect SET offers excellent build, a small footprint and performance orders of magnitude beyond its very reasonable ask. How much more would you have to spend to equal or surpass it? It could mean many multiples of its own sticker. The Perfect SET can be driven by low-power SET and high-power transistor amps with equal success and it's small enough to fit into many acoustic spaces.
The Perfect SET has great transparency and bandwidth (30Hz to 30KHz) and is linear across the range, therefore seamless from top to bottom. It has the speed and quickness of a horn design but images like a small two-way monitor. "
Made under U.S. Patent (contact info removed)
The Perfect SET – designed and optimized for ‘single-ended triode’
Proprietary controlled directivity – acoustically superior proprietary polygon-oriented, triple-ring radiator high frequency array. This array disperses a precisely focused acoustical power pattern of that of a horn or waveguide without the audible ringing influence of horn flare walls constraining the soundwave for acoustically superior mid-range high frequency performance ​
12″ Ulfberht Transducer
96dB 2.83V@1m sensitivity
8 Ohm impedance – for optimum ‘single-ended triode’ performance
Linear 30Hz-30kHz frequency response
Minimum input requirement: 1 Watt RMS
300 Watts maximum power handling
Dimensions: 41.5″ H x 14.0″ W x 13.0″ D
Weight 70 lbs.
Manufactured in the USA
