Where can I find 4.4mm to xlr cables?
0 Members and 1 Guest are viewing this topic. Read 6710 times.
rif
  • Not a cowboy
« on: 15 Dec 2022, 05:04 pm »
seem to be very few options in the places I usually look. I found one on Amazon, youkamoo, but thats pretty much it.
this is for the audio zen phono preamp.
djpk
Re: Where can I find 4.4mm to xlr cables?
« Reply #1 on: 15 Dec 2022, 05:12 pm »
I bought the youkamoo cable that you mentioned and it seems to be functioning quite well. iFi Audio also has a 4.4mm cable, but it is 1 meter and it is too long for my application.
I.Greyhound Fan
« Reply #2 on: 15 Dec 2022, 05:31 pm »
I found one here:
https://hartaudiocables.com/products/tc-3-4-4mm-pentaconn-to-dual-3-pin-xlr?variant=37991496024250
I recently bought one. It uses Mogami wire and Neutrik connnectors.  He can make them in custom lengths, just send an email.  They are made in Texas.  I received mine the same week I placed the order.
charmerci
« Reply #3 on: 15 Dec 2022, 08:00 pm »
Try Audio Envy. They make custom cables at a very reasonable cost.
