FS: Dayton Audio SA230 Subwoofer Amplifier
0 Members and 1 Guest are viewing this topic. Read 628 times.
Early B.
« on: 13 Dec 2022, 06:03 pm »
Get rid of that cheap plate amp on your subwoofer and replace it with a better-looking and better-sounding amp. The SA230 will destroy 99% of all plate amps. Besides, why would you want an amp installed on a cabinet behind a huge woofer??? -- it's gonna vibrate like crazy!
Dayton Audio's SA230 subwoofer amplifier delivers clean, solid power to drive a typical subwoofer. The SA230 is engineered to provide high-fidelity subwoofer amplification. Its variable gain, bass boost, crossover frequency, and phase adjustment guarantee perfect integration with any audio system in any listening environment.
Specifications: • Rated power output (1% THD): 156 watts into 8 ohms, 233 watts into 4 ohms • Signal to noise ratio: 85 dB A-weighted • Input impedance: 12K ohms • Input sensitivity: 75 mV • Gain: 0 dB to +10 dB • Bass boost: 25 Hz to 50 Hz • Low pass adjustment: 40 Hz to 180 Hz @ 18 dB/octave • Phase adjustment: 0° to 180° • Dimensions: 17-1/4" W x 3-3/4" H x 13-7/8" D • Weight: 21.05 lbs.
This amp has never been used. Price is $175 shipped in the continental USA.
