0 Members and 1 Guest are viewing this topic. Read 2084 times.
It would be excellent if we could upload and remove music from the drives without unplugging them!
MM can do this already through SAMBA. It is a bit slow and clunky but the functionality is there
I’m wondering if the new MM replacement will allow users to access the attached hard drives through the network.It would be excellent if we could upload and remove music from the drives without unplugging them!Any chance?TIA
on the Dashboard under the Services tab is where you activate Samba. What is you PC windows/Mac/Linux?
I'll reiterate what others have already confirmed and that Manic Moose already does this and its replacement will as well, likely in a similar fashion although perhaps will either think of some ways or someone will suggest some improvements to the feature.
After Samba enabled on BDP, make sure your on the same network as the BDP. from the finder menu Go-->Network. Does the BDP appear in the list? If it don't watch the vid belowvid on how to connect to the samba sharehttps://www.youtube.com/watch?v=pZw6qhjR-HE
I'll reiterate what others have already confirmed and that Manic Moose already does this and its replacement will as well, likely in a similar fashion although perhaps will either think of some ways or someone will suggest some improvements to the feature.ChrisChris
I believe bothjames
