Where have all my posts gone ??
0 Members and 1 Guest are viewing this topic. Read 972 times.
Garster
« on: 11 Dec 2022, 10:43 pm »
Hi, I've been out of the circle for a few years now. I became a member in 2007 and have bought, sold and posted here, I'm looking to purchase some Odyssey equipment here but can't do any purchasing because somehow all may history is gone. What give's, any help or info is appreciated..
adminRH
  • not admin
Re: Where have all my posts gone ??
« Reply #1 on: 11 Dec 2022, 11:38 pm »
Hi Gary, welcome back!
The best avenue would be to make a post in the Login Help Circle. You can post there without logging in.
I searched all member names with “gar” and couldnt find anything similar to Garster or your email address.
So please remind us what was your previous username on AC so we can find and reactivate your account.
You can also post the email address that you used with the old username to help find it. I will scrub the email after we fix it.
adminRH
  • not admin
« Reply #3 on: 12 Dec 2022, 12:46 am »
Welcome again.
Garster
« Reply #4 on: 12 Dec 2022, 12:55 am »
I've used [email protected] here, can't remember others. My user name has always been Garster here. Thanks
« Reply #5 on: 12 Dec 2022, 01:20 am »
Hi Gary,
I believe you are referring to your posts from your second account Gary_V from 2005, fortunately your 13 posts are all there.
https://www.audiocircle.com/index.php?action=profile;u=4509
« Last Edit: 12 Dec 2022, 02:37 am by FullRangeMan »
adminRH
  • not admin
« Reply #6 on: 12 Dec 2022, 04:24 am »
Thanks FRM!  :thumb:
Gary, your old username is Gary_V
Gary_V now has your new email address that you used to register Garster, so login and change your password and you should be all set.
Report success or any problem here.
adminRH
  • not admin
« Reply #7 on: 12 Dec 2022, 05:51 pm »
I see you were able to log in as Gary_V.   :thumb:
Gary_V was registered in 2005, made 13 posts in the past. Gary_V acct is using your current email address.
Garster was registered in 2007, but didn't make any posts until this thread. Garster current has a broken email address.
You can only have one account, so pick which one you want to keep and let me know asap. The other will be locked.
If you want to keep Gary_V account with the previous posts, you can still change the displayed name to show Garster, while the underlying account username is Gary_V.  Details: https://www.audiocircle.com/index.php?topic=138706.0
If I don't hear from you soon I will lock Garster account so you can use Gary_V.
