Interruptions when playing music from Qobuz on BR-20
0 Members and 1 Guest are viewing this topic. Read 964 times.
alanford69
Hello, I am experiencing the following issue:
- I add a Qobuz playlist to the BR-20 queue using the Moose’s media player
- I start playing the playlist but randomly after 3-4 songs I hear nothing, the display still shows the song name but all bitrate leds are off (see image)
- there’s nothing I can do but power cycling the BR-20 to hear music again
Anybody experienced this? How to solve?
  • The Demo is Everything!
    • http://www.bryston.com
Re: Interruptions when playing music from Qobuz on BR-20
« Reply #1 on: 8 Dec 2022, 11:55 am »
Hi Alan
I use Qobuz and so far no issue.
Are you using a wired ethernet - maybe network related?
Are other sources all OK?
best
james
alanford69
« Reply #2 on: 8 Dec 2022, 12:27 pm »
Thanks James, I connected the BR-20 to my router using a cable. Before I had a Cambridge CXN v2 connected to the network in the same way and had no issue. I tried a network reset pulling the knob of the BR-20 in the System menu but nothing changed.
Balanced connection is working fine, I tried with my CD player and sound fantastic. I have no other device connected.
As I said if I power cycle the BR-20 everything work as before but after playing few songs I have to do it again. Is there a way to restart MPD without power cycling the entire BR-20?
« Reply #3 on: 8 Dec 2022, 12:59 pm »
Email Adam and see if he can help.
[email protected]
james
alanford69
« Reply #4 on: 8 Dec 2022, 02:11 pm »
Thanks James, will do.
Highendfool
  • It is what you think.
« Reply #5 on: 8 Dec 2022, 03:04 pm »
Thanks James, ……….. Is there a way to restart MPD without power cycling the entire BR-20?
In ManiccMoose restart the MPD
alanford69
« Reply #6 on: 9 Dec 2022, 02:41 pm »
Hi, in settings I have only this option, anyway Adam and Chris are looking into it.
Thanks for the great support that Bryston is providing!
