BR-20 Bypass Remote codes
0 Members and 1 Guest are viewing this topic. Read 590 times.
sep297
« on: 5 Dec 2022, 05:22 pm »
I have had a few updates to firmware etc on my various systems which means I have to update some of the delays etc on my harmony remote and I am struggling with triggering the bypass when I start my home theatre system.
I have noticed that the 'Bypass on' seems to have changed into a 'toggle bypass' command as it will switch it off as well as off which from an automation point of view gives me a couple of headaches.
So currently I am using the following.
Bypass Mode On   244
Bypass Mode On/Off   245
Bypass Mode Off   246
I just want to check this is still correct before I start playing with it too much.
Regards
Stuart
