IDA-6-How do I connect a sub?
0 Members and 1 Guest are viewing this topic. Read 2154 times.
JCarney
« on: 5 Dec 2022, 12:20 am »
No sub out so I'm not sure if it is even possible.
Thanks for any and all help,
JCarney
mresseguie
Re: IDA-6-How do I connect a sub?
« Reply #1 on: 5 Dec 2022, 12:44 am »
Can you run the speaker wires to the sub abd then continue to the speakers? [Not every sub's amp plate has this capability.]
<ichael
JCarney
« Reply #2 on: 5 Dec 2022, 12:58 am »
No sir. No required inputs. I looked at the manual, the unit, the sub and I just did not see a way to hook one up. Members are always finding work arounds for things, I was hoping for one of those. It just may not be possible.
Thanks for the effort,
JCarney
opnly bafld
« Reply #3 on: 5 Dec 2022, 01:35 am »
Giving more info is always best when asking questions like this.
What subwoofer?
Speaker to line level converters are an option if the sub has L and R rca inputs.
JCarney
« Reply #4 on: 5 Dec 2022, 02:02 am »
The sub is the dirt cheap Jamo S808. It literally only has a single ended line in, no L and R. Not one of my best purchases, other then I payed around $80 for it new.
Thank You for the good question,
JCarney
mresseguie
« Reply #5 on: 5 Dec 2022, 02:07 am »
I've glanced at both the Jamo sub's plate and the rear panel of the IDA-6, and it appears to me that they are incompatible.  :scratch:
opnly bafld
« Reply #6 on: 5 Dec 2022, 02:56 am »
JCarney
Get another one, then you will have a L and R input.
JCarney
« Reply #7 on: 5 Dec 2022, 03:06 am »
That is my assessment as well.
Good idea, unfortunately not practical, and I don't think I can find one at $80ish again. I'm not going to sweat it. Hooking it up was a want more than a need. Thank You both for helping me get to that conclusion.
JCarney
