Hex Screw Size for Dodd Remote?
0 Members and 1 Guest are viewing this topic. Read 1535 times.
mboxler
« on: 23 Nov 2022, 03:37 pm »
Missing one, and it kinda bugs me.  Anyone know what it is and where I can get one?
Mike
Big Red Machine
Re: Hex Screw Size for Dodd Remote?
« Reply #1 on: 23 Nov 2022, 06:04 pm »
Looks like a 2-56 Allen head. About 1/2" long?
mboxler
« Reply #3 on: 23 Nov 2022, 06:36 pm »
5/8" from base of screw to end.  I'll check Ace.  Maybe I'll get lucky.
Jstower
« Reply #4 on: 23 Nov 2022, 10:07 pm »
It measures 2.15 mm in diameter and 19.63mm long (20mm)  the thread pitch is metric 0.45 matches as I look under the microscope. My Metric thread Pitch gauge only goes down to 0.45 and it could be 0.40 which is very close in size. So your best bet is to look on eBay, or buy 6 screws that are similar.
I’m thinking it’s M2 0.40 x 20mm.  Good luck
Link:  https://www.ebay.com/itm/132318243973?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=zRMH5lUdRle&sssrc=2349624&ssuid=jgiqrzzKRsi&var=&widget_ver=artemis&media=COPY
Danny Richie
« Reply #5 on: 23 Nov 2022, 10:32 pm »
I might have one. I will have to bring one of my remotes over and pull one out to check it.
SoCalWJS
« Reply #6 on: 23 Nov 2022, 11:09 pm »
Definitely worth a shot. I’m pretty sure I’ve seen something VERY similar at my local Ace.
wingsounds13
« Reply #7 on: 25 Nov 2022, 09:32 pm »
Those small bolts will be available at your local hobby shop (if you have one).  Very common in model aviation and cars.
J.P.
