Which one is better?paradigm persona 3F + persona C or revel F226Be + C426be
0 Members and 1 Guest are viewing this topic. Read 4290 times.
Mathin
the paradigm is more expensive. Is it worthy to choose it?
richidoo
Welcome to AudioCircle, Mathin!
I have 3F and I love it.  Both are well engineered and quality construction. 3F made in Canada, 226 made in Mexico or China.
Main advantage of 3F is the Be midrange driver. Main advantage of the Revel is the tweeter waveguide, imo.
3F has a dispersion screen over the tweeter which seems to work well.
Revel is all 4th order Linkwitz Riley crossover filters, while the Paradigm is all 3rd order xo filters.
All Revels have a tighter, more controlled "hifi sound" while Paradigm is a little more open and loose, imo.
They both have overachieving bass, meaning small box, small bass drivers, big WAF, tries to compensate for lack of cone area with reflex port. Forward facing port on Revel is technically more correct (louder, punchier) but the downward facing partially obstructed port of Paradigm tries to tame the traditional reflex punchy sound to make it a little more musical. But spikes are required on carpet as the port shoots out the bottom.
Revel might have an advantage in slightly cleaner bass, only based on my past Revel listening experiences, as I have not heard 226. But physics rules bass and they are pretty similar design.
The detail from the Be drivers are amazing. Personas are the only speaker that has a Be midrange and it is astonishing.
Revel has ceramic coated aluminum cones which are very stiff and self damping like Be.
The Be midrange really reveals the character of the amplifier. A receiver amp/DAC might not do it if you have a golden ear.
They are both speakers worthy of high end electronics.
I heard the 5F and bought the 3F. The 5F has cleaner bass. I am trying to avoid hearing the 9F.  :wink:
It's nice that you have the choice between two great speakers. I think you'll be happy with either.
Enjoy!
Mathin
two paradigm persona sub and one paradigm sub2 which is better?
« Reply #2 on: 18 Nov 2022, 05:51 pm »
persona sub has a better look
Mathin
How important information.Thank you so soso sososo much.
Mathin
The biggest problem is that the paradigm center channel is much more expensive then the revel one,too difficult to make the decision.
Mathin
I gonna buy one more A21+ to build my theater
Phil A
Welcome to AC!
richidoo
Then go with the Revels. Price is important and you can't go wrong with either, imo.
Revels might even have better long term resale value if that matters to you.
Hi,
I will merge these 3 topics you started in the Starting Block Circle into one.
Greetings & Welcome to AC Mathin   :thumb:
Mathin
Welcome to AC!
Thank you brother
Mathin
Thank you brother, everyone is so nice.
Mathin
Hi,
no problem boss
Mathin
Thanks again, your opinions are so useful.
Mathin
used parasound a21+(just got) has left channel sonic boom problem
« Reply #14 on: 19 Nov 2022, 04:31 pm »
the seller is calling UPS with shipping damage.
When it is cold, turn it on,sonic boom happens on left channel,last about one minute then be fine.
Will this problem hurt my speaker? Will it be a potentail problem? Must I fix it?
 Please everyone,thank you so much.
I.Greyhound Fan
Yes, it must be fixed, and it can damage your speakers.
Rusty Jefferson
And it's unlikely a shipping problem. Hope you didn't pay with Friends and Family.
Hi,
I will merge this topic with the others you started in this Circle.
GUIDELINES
Mathin
Oh my God, that would be a big problem
Mathin
Actually I did, what should I do, seems like a big problem
