On GR Website - NX Studio Finished Cabinet Problem
0 Members and 1 Guest are viewing this topic. Read 1486 times.
alaska_grown
« on: 17 Nov 2022, 12:41 am »
Hi GR!
Just wanted to let you know of an issue on the website. The NX Studio Finished Cabinet page only the selection of the Maple Baffle allows choosing a side panel option. The other baffle choices (Mahogany, Walnut, etc) do not offer any side panel option on the drop down so the order cannot be completed.
The Completed Studio pair page is fine.
Hobbsmeerkat
Re: On GR Website - NX Studio Finished Cabinet Problem
« Reply #1 on: 17 Nov 2022, 05:31 am »
Thanks for the heads-up I'll fix that in the morning. :thumb:
Edit:
Fixed. Oddly enough, everything was set correctly, but wasn't working correctly.
Had to purposefully break it to fix the issue. go figure. :roll:
« Last Edit: 17 Nov 2022, 04:25 pm by Hobbsmeerkat »
NXSTUDIO-DRUMMER
FYI,
I've also noticed the demensions on the studio's are incorrect, I believe on the GR RESEARCH online website as well. This is what is listed on the GR site, 24 × 18 × 18 in, 24 × 18 × 18 in. :scratch:
« Last Edit: 19 Nov 2022, 11:55 pm by NXSTUDIO-DRUMMER »
Hobbsmeerkat
« Reply #3 on: 17 Nov 2022, 10:04 pm »
That's a rough shipping box dimension for each cabinet. It's a problem with most all of the kits on the website that we can't adjust.
Danny's design is taller but a little shallower at 18″H x 8.5″W x 15.5″D which is the size the assembled cabinets are.
Jay's newer cabinets are the same size, but I believe the tweeter and woofer were moved up closer to the top of the speaker.
I've added the cabinet dimensions to the product page.
Elen
« Reply #4 on: 8 Dec 2022, 07:57 am »
thanks for fixing that
appreciated  :thumb:
