Converting w64 files to wav
0 Members and 1 Guest are viewing this topic. Read 2167 times.
Don_S
« on: 3 Nov 2022, 05:50 pm »
I need to convert an entire drive to .wav. Most of the files are w64 but some are .aiff and some are FLAC. Is there a program that will convert all at the same time?
I realize I may have to do small batches if the current formats are different.
I see many free programs offered but I have no way of knowing which ones work best. I would appreciate any experienced replies. My priority is the w64 files.
I have an external HDD drive which is a backup drive to my music server. I am getting an Aurender and need to convert. First I will convert to a new external drive then I will transfer the files to the Aurender.
This is going to be a horrible project. I have about 1.5TB of music which isn't a lot by some standards. But it is enough to be time consuming if I have to pick and choose small batches because of their current format.
I think I only need to convert the w64 files but formats are mixed on the backup drive. If a conversion program automatically skips non-w64 files in the mix I can work with that for now.
Mag
Re: Converting w64 files to wav
« Reply #1 on: 3 Nov 2022, 09:26 pm »
 You can try Leawo Music Recorder I tried it but can't get it to work, conflict in software. It'll convert files to wav but not at CD quality. Another option that I know of is a Tascam Professional CD Recorder. But this will set you back a couple hundred bucks plus spools of CD-Rs. Plus you need to be able to connect to it which if you're using a computer maybe a problem but can easily be solved with a wireless bluetooth amp.
An ideal solution would be to save the converted files to a usb stick which you would need a few. An an external drive would work as well.
1.5 TB of music could take a life time, try to narrow it down to just your favorites. :smoke:
newzooreview
« Reply #2 on: 3 Nov 2022, 11:42 pm »
I use xact for batch audio file conversion. I can just drag a folder into the conversion window and it pulls all the audio files. It ignores other files in the folders (but does pop up a note that some files were ignored.) It reads through nested folders.
It has a setting to delete the original, so it would be easy to have a duplicate drive (keeping a spare of the original files), and letting it ingest the top-level folder and convert to WAV, deleting the originals as it goes. You would then have the same folder structure with WAV files in place of the original formats.
http://xact.scottcbrown.org/
It is Mac only. What system are you using?
Don_S
« Reply #3 on: 4 Nov 2022, 12:04 am »
OK, that was  :scratch: I am using Windows
WGH
« Reply #4 on: 4 Nov 2022, 12:05 am »
Looks like dBpoweramp will Batch Convert everything at once or just the format you pick
https://www.dbpoweramp.com/Help/dMC/FileSelector.htm
A short thread how to make sure the folder.jpg gets moved too
https://forum.dbpoweramp.com/showthread.php?41537-Converting-W64-32-44-1-to-WAV-or-FLAC
Probably should do a small test first before turning it loose converting 1.5 TB
Don_S
« Reply #5 on: 4 Nov 2022, 12:08 am »
Thanks. I will definitely look into that. I just ordered the new drive so I can't do anything until I get it.
https://www.amazon.com/gp/product/B0874XWW23/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
Don_S
« Reply #6 on: 4 Nov 2022, 12:23 am »
I do not see w64 listed (I do not mean .wav64).
https://www.dbpoweramp.com/Help/dMC/dMC.htm
WGH
« Reply #7 on: 4 Nov 2022, 01:13 am »
W64 is listed under Additional Codecs:
https://www.dbpoweramp.com/codec-central.htm
Wave64    Sony extension to the wave format  [.w64]
Hover mouse pointer over Wave64, click and you will get to the Wave64 page and the link to download additional codec "Wave64 Release 2"
https://www.dbpoweramp.com/codec-central-wave64.htm
Don_S
« Reply #8 on: 4 Nov 2022, 01:31 am »
Thanks.
