In line filters
0 Members and 1 Guest are viewing this topic. Read 830 times.
Ear Rake
In line filters
« on: 28 Oct 2022, 03:21 am »
Hi I'm new to the site. I see i Day's videos on YouTube he mentions i line filters. Do you sell these or are these a kit, or how do I get my hands on them?
NoahH
Re: In line filters
« Reply #1 on: 28 Oct 2022, 01:25 pm »
They need to be custom made based on the input and output impedencies of the devices on either side (preamp and amp usually). If you can get those measurements (usually in the docs for the devices), folks here can give you direction for how to get the right capacitor values. Then you just wire a junction box with the capacitor in the path.
Hobbsmeerkat
Re: In line filters
« Reply #2 on: 28 Oct 2022, 03:30 pm »
Not quite,
Inline filters are based in the input impedance of your power amplifier or monoblocks. (Assuming you have separate amps and preamps)
Once we know that information, along with where you want the roll off to begin(between 40-80Hz), and if you are using RCA or XLR connectors, we can help get you started on the cap values that will be necessary for your system. (if you change amps in the future, the filters will also have to change unless they have the same input impedance)
if you are using a AV Receiver, most of them have a built in high-pass filter by setting the speakers to "small"
if you have an integrated amp, it's often not possible to implement a high-pass filter.
Hafgrim
Re: In line filters
« Reply #3 on: 5 Nov 2022, 03:56 am »
I also need some help from some who can do the math. My amp's input impedance are 100kohm,
What values would I need for -6,-12 db at 50 and -6,-12db at 40.
