Vision SLR preamp into a passive line level crossover
0 Members and 1 Guest are viewing this topic. Read 1378 times.
ytl
I have been happily using a Vision SLR preamp (with 2 phono boards  :wink:) for several years, with one set of outputs into an Aragon 4004MkII amp in turn into Acoustic Energy AE1, second set of outputs into Hsu ULS15 subwoofer.  I'm considering a passive high pass filter after the Vision SLR.  The top candidate is Marchand XM46 which has an input impedance of ~1k ohm.  This is 1 or 2 orders of magnitude lower than most power amplifiers.  Will this be a concern?  This will be in parallel with the input impedance of the ULS15 which I cannot find in the specs, but I presume it'll be reasonably large.
The output impedance of the Vision SLR is not published in the specs.  Perhaps Frank can shed some light.
Anyone using a similar setup?  The obvious alternative is to use an active crossover, but the passive version seems quite attractive to my (totally subjective) purist self.  Plus, I already have a low pass filter in the ULS15.
Ying
avahifi
    • http://www.avahifi.com
Re: Vision SLR preamp into a passive line level crossover
« Reply #1 on: 31 Oct 2022, 01:17 am »
Running your preamp into a very low impedance load will certainly reduce system gain.
How it will interact with the crossover network I don’t know.
Probably no harm in trying it.
Frank
ytl
« Reply #2 on: 1 Nov 2022, 10:36 pm »
Thank you Frank.
Gain is not an issue in my setup; I sometimes opt for using the low gain switch on the preamp.  I'm more worried about the impact, if any, on the frequency response.  I just might have to try it.
There are very few commercial passive line level crossovers.  As far as I know, Vandersteen is the only other manufacturer that has such an offering which have some impedance matching switches (at >5X the cost of Marchand).  Interestingly they only offer passive high pass to be used with some of their top speakers.
Ying
