BDP-3 MM Qobuz Sample Rate Issue
0 Members and 1 Guest are viewing this topic. Read 1827 times.
galyons
« on: 26 Oct 2022, 12:06 am »
Attention Manic Mouse + qobuz users!  Need some help.  I cannot get Manic Moose to recognize that my Qobuz Studio account is limited to 96/24 sample rate. My DAC only plays up to 96/24 sample rate. Manic Mouse is passing through 192/24 files full rate.  So those files now will not pay through the BDP-3 to my DAC. I just get silence.
Anyone faced this issue?   Qobuz thinks it is a Manic Moose issue.
Geary
freshaudio
Re: BDP-3 MM Qobuz Sample Rate Issue
« Reply #1 on: 26 Oct 2022, 12:32 am »
I have changed my Qobuz sample rate to Lossless instead of Studio  so only 96/24 streaming
galyons
« Reply #2 on: 26 Oct 2022, 12:56 am »
Thanks for the response. Sorry, I am not quite following your statement.  There are only two Qobuz subscription plans, Studio and Sublime. The only difference between the two plans is the discounts on Hi-Res purchases of up to 60%.  My account profile is set to cap streams at 96/24.  Qobuz sends 192/24 files to my equipment at 96/24 files.  For some reason playing qobuz through Manic Moose the 192/24 files come through at 192/24, instead of my qobuz account limit of 96/24. Those files will not play on my DAC, so they play as silence.
Are you saying that Manic Moose passes the qobuz 192/24 files as 96/24 because of your Qobuz account bandwidth limit? If so, that is what I want.  How do I configure Manic Moose to do that?
vonnie123
« Reply #3 on: 27 Oct 2022, 01:59 am »
Can you go into more depth regarding equipment (DAC) cabling etc.  are you playing Qobuz via Roon, or MM?
MM services settings MPD, DLNA?
Qobuz settings within MM?
galyons
« Reply #4 on: 27 Oct 2022, 03:44 am »
Sorry. I found those settings in MM.  I was set to Studio. I tried 24bit lossless, but it made no difference. Files were still delivered at 192/2, even though my setting is for 96/24 in Qobuz.
Geary
galyons
« Reply #5 on: 27 Oct 2022, 04:00 am »
Playing via MM, no Roon. MM is via MPD. The settings for MM Qobuz is Studio, but I tried it other settings with no difference achieved. I am running the BDP-3 with Ethernet from a WiFi bridge. My bandwidth is 150mB/sec.  The BDP-3 is wired via AES/EBU to an AD1865 chip based ANK DAC4.1.  DAC out is RCA to my preamp, Bottlehead BeePre. Power amps are Bottlehead Paramounts. Speakers are rebuilt EV Sentry IV 3 way horns.
Qobuz thinks that the issue is with MM as my actual Qobuz settings are correct to send files above 96/24 as 96/24.
Hope this helps.
Geary
vonnie123
« Reply #6 on: 27 Oct 2022, 04:36 am »
Can you get the player to function (sound is heard) using the 16 bit CD MM setting.  I'm guessing the BDP-3 is processing the 24/192 signal, but your DAC can't interpret it.  SWAG....
Is the BDP-3 playing the songs on the screen on the MM screen, but no music is heard?
galyons
« Reply #7 on: 27 Oct 2022, 05:36 am »
I think we have it. I the set MM Qobuz setting to 24bit lossless and then rebooted the iPad. I rebooted the BDP-3, launched MM and now I am getting the 96/24+ files as 96/24.  Thank you freshaudo and vonnie123!  I am not a computer audio guy, mostly analog.  I should have remembered the computer “fix all”...reboot!
Geary
ncaahockeyfan
« Reply #8 on: 24 Feb 2024, 04:36 am »
I am having a similar type of issue. My DAC supports 192k but occasionally and unexpectedly reboots while streaming 192k tracks. It's never happened on 96k or less tracks. I am going to change this setting in MM too, but am curious if this setting filters out 192k tracks from the qobuz library or does my BDP-2 down sample the higher bitrate tracks to 96k?
« Last Edit: 24 Feb 2024, 02:48 pm by ncaahockeyfan »
