VMPS larger subwoofers
0 Members and 1 Guest are viewing this topic. Read 999 times.
Cadlac
« on: 14 Oct 2022, 08:41 am »
Looking to replace my Klipsch pro 15s with 2 KMPS larger subs, wondering the best way to connect in bridged mode
Re: VMPS larger subwoofers
« Reply #1 on: 14 Oct 2022, 11:18 am »
Connect an stereo amp in bridge?
Speakers are connected in Series or Parallel.
« Last Edit: 14 Oct 2022, 02:19 pm by FullRangeMan »
Cadlac
« Reply #2 on: 14 Oct 2022, 12:50 pm »
Am I the 1st to bridge an amp? :lol:
« Reply #3 on: 14 Oct 2022, 12:54 pm »
Greetings & Welcome to AC Cadlac   :thumb:
« Reply #4 on: 14 Oct 2022, 02:29 pm »
You didn't say what equipment was, some amps cannot be bridged, check with the manufacturer.
opnly bafld
« Reply #5 on: 14 Oct 2022, 02:45 pm »
With 2 subs why would you want to?
Run the amp stereo or dual mono (if using a mono output).
« Reply #6 on: 14 Oct 2022, 03:00 pm »
Unless the VMPS subs are free, what do you think you'll gain by having them in your system? VMPS is long gone with little to no replacement parts available. I don't see an upgrade here.
rbbert
« Reply #7 on: 15 Oct 2022, 12:29 am »
For the subs replacement parts are probably not an issue.  The amps are Dayton and readily available, drivers are off-the-shelf as well.  OTOH I agree the price should be low, since an experienced cabinet maker can build these.  Whether they would be an improvement I can't say, since I don't know the current subs; the Larger Subs may be as big or bigger than those main speakers
