Audiophile Ceiling Speakers as OB drivers?
0 Members and 1 Guest are viewing this topic. Read 1774 times.
Rancho
« on: 13 Oct 2022, 05:07 pm »
Many of the high end audio companies offer extreme high quality ceiling mount speakers that are designed for zero enclosure.
How would they work in OB designs?
Example:
https://www.crutchfield.com/S-ZkafFt2HIMr/p_749CCM683/Bowers-Wilkins-Performance-Series-CCM683.html?awcr=77240787915370&awdv=c&awkw=audiophile%20ceiling%20mount%20speakers&awmt=e&awnw=o&awat=&awug=&msclkid=a133484c661b1ca123382b0422882751
mcgsxr
Re: Audiophile Ceiling Speakers as OB drivers?
« Reply #1 on: 14 Oct 2022, 01:22 pm »
Given they are meant to be IB loaded I would expect their specs (QTS, XMAX etc) would be a good fit for OB.
Many folks could begin their OB exploration affordably with car speakers - most are also designed to work without an enclosure.
At this price point for the B&W there may be other purpose built drivers to consider also.
WGH
« Reply #2 on: 14 Oct 2022, 04:27 pm »
$600 per driver seems like an expensive experiment, of course they could always be re-used in a ceiling.
A friend had the early Emerald Physics open baffle speaker that used a PA speaker, to me it sounded like a PA speaker mounted in a sheet of plywood with imaging close to the floor because they were so low.
The B&W speakers might sound like ceiling speakers mounted in a sheet of plywood.
The adjustable tweeter would be helpful raising the sound higher.
If you want to DIY then there are many examples and you could learn from other successful designs.
The best affordable DIY open baffle loudspeaker I've listened to so far
https://www.audiocircle.com/index.php?topic=99369.msg1000266#msg1000266
>> Google search for 8" open baffle speakers <<
     https://www.google.com/search?q=8%22+open+baffle+speaker&source
