Industry Circles
Bryston Limited
BDP-2 throwing Error 3
0 Members and 1 Guest are viewing this topic. Read 771 times.
inglisd
10 Oct 2022, 02:08 am »
right in the middle of great sound and sharing with my kids, nieces and nephews
the BDP-2 died ? Error 3, powered off, on cant access the web UI. Any ideas ?
OTM
Re: BDP-2 throwing Error 3
10 Oct 2022, 06:22 am »
Could check here:
http://support.bryston.com/downloads/BDP/Manic%20Moose%20Manual.pdf
Did you try unplugging?
inglisd
Reply #2 on:
10 Oct 2022, 02:17 pm »
powered off, then on, but it didnt do the usual power down cycle. Unplugged it, same thing.
It eventually corrected itself.
OTM
Reply #3 on:
11 Oct 2022, 12:10 am »
Happy Thanksgiving
vonnie123
Reply #4 on:
11 Oct 2022, 04:02 am »
http://support.bryston.com/downloads/BDP/BDP-error-codes-20140211.pdf
Might be a good idea to pull the top, and make sure the fuses are correctly seated. There are two fuses installed.
I’ve had that failure before and the fuse was the culprit. Did you move or jar the unit?
inglisd
Reply #5 on:
11 Oct 2022, 03:40 pm »
thanks for the replies all. I have moved the unit a few times to install upgraded XLR and SE cabling.
I will have a look inside ...
Industry Circles
Bryston Limited
