No Rez characteristics
0 Members and 1 Guest are viewing this topic. Read 734 times.
Martin Garrish
« on: 8 Oct 2022, 08:37 pm »
Hi, all.
I'm currently developing a pair of transmission line cabinets for small fullrange drivers using the latest computer methods. I have run into problems with midrange leakage from the TL port before I can decouple the line from the driver. Some additional calculations tell me that I could use No-Rez damper sheet/foam to increase the TL cross section depth without altering the acoustic impedance. The problem is that I don't know the acoustic properties of No-Rez, and I can't search this forum until I've put in three posts.
Can anyone tell me their experience of how lining a cabinet with No-Rez affected the volume for Thiele-Small parameters? I imagine that like the GAW fibre I favour the volume reduction is actually compensated by the change from adiabatic to isothermal compression. So for example lining a reflex cabinet with No-Rez actually has no effect on the cabinet acoustic volume (compliance). :?
Mart
Danny Richie
    • http://www.gr-research.com
Re: No Rez characteristics
« Reply #1 on: 9 Oct 2022, 02:09 pm »
That is correct.
Martin Garrish
« Reply #2 on: 10 Oct 2022, 09:05 am »
Much obliged, Danny.
Found the videos I was after.
Video on NoRez: https://www.youtube.com/watch?v=uDXC6TkaQ1E&t=8s
Video on poly-fil: https://www.youtube.com/watch?v=QvQRRU68FM4
Found a neat acoustic trick using just poly-fil to keep that pesky midrange inside the cabinet. Any advice on cabinet size adjustment for poly-fil?
Ideally, these TLs will be the most boring speaker ever developed - the excitement is in hearing every detail of the music...
Mart
