Hi from New Brunswick, Canada
0 Members and 1 Guest are viewing this topic. Read 1082 times.
miek_g
« on: 6 Oct 2022, 04:24 pm »
I have been looking st the XLS-Encore for quite some time and think I am ready to take on the task.
new user, so I cannot use the search feature.
I had thought I had seen a thread where Danny had plas for a front slot version.   with my room constraints a rear firing port will not work for me.
Danny Richie
    • http://www.gr-research.com
Re: Hi from New Brunswick, Canada
« Reply #1 on: 6 Oct 2022, 08:25 pm »
If you build the X-SLS version you can easily flip the port to the front side.
You can also build the X-LS model as a sealed box.
miek_g
« Reply #2 on: 11 Oct 2022, 03:51 pm »
thanks Danny,
are the crossovers the same for the floor model?  I may be able to look at the floor model?
what are the downfalls of running as a sealed unit?
cheers
Hobbsmeerkat
« Reply #3 on: 11 Oct 2022, 06:31 pm »
Both versions of the X-LS use the same crossover. (Same with the X-CS & MTM)
Sealed will have limited bass output, as it will have a roll off starting around 70Hz. The ported version is tuned at 55Hz and the tower version is tuned for 45Hz.
miek_g
« Reply #4 on: 19 Oct 2022, 05:22 pm »
Thanks Hobbs.
 is 6" acceptible for the ported or what would you reccomend?
I figure, if the roll off is 70Hz I can let my sub kick in at 80Hz or so to make up for it.
Hobbsmeerkat
« Reply #5 on: 20 Oct 2022, 03:44 am »
6" of airspace behind the speaker? That's about as close as I would recommend. But further will be better if possible.
And you want your subs to come in below the roll off point, closer to 50Hz for a sealed speaker otherwise youll get a big spike (or hole depending on phase) in output throughout the midbass, where they overalap.
If you have the speakers ported you'll want the subs set to about 35-40Hz.
miek_g
« Reply #6 on: 3 Nov 2022, 03:30 pm »
Thanks Hobbs, Danny
I just received my shipping confirmation the other day for the XLS-Encores :)
I will be building them as sealed units, my current Center channel, Paradigm CC-170 have the following specs, so it will match better
  • Low Frequency Extension (DIN)   50Hz (DIN)
    Frequency Response   70Hz - 20kHz, + / - 2dB
I will try the sub at 50Hz and play around with it.
