Mini Tweeter
0 Members and 1 Guest are viewing this topic. Read 981 times.
JCarney
Mini Tweeter
« on: 2 Oct 2022, 01:31 am »
One of the tweeters on one speaker has had a little finger on it and dented it in a bit. Is there a recommended/safe way to return the tweeter to a dome shape? I hesitate due to the delicateness of the dome material. Any and all help is appreciated. This is the pair that her and I built for her.
JCarney
planet10
  • Frugal-phile (tm)
    • planet10-hifi
Re: Mini Tweeter
« Reply #1 on: 2 Oct 2022, 06:06 pm »
Disssemble the tweeter anf push thr dome out from the backside. A metal tweeter (and some others like T27) will not come back completely.
dave
JCarney
Re: Mini Tweeter
« Reply #2 on: 2 Oct 2022, 06:20 pm »
Thanks Dave, I appreciate the guidance. I've never disassembled any driver, so this will be a new adventure.  :o :lol:
JCarney
planet10
  • Frugal-phile (tm)
    • planet10-hifi
Re: Mini Tweeter
« Reply #3 on: 2 Oct 2022, 06:27 pm »
If it is a cheap tweeter you wil unlikely be able to disassemble it.
What kind of tweeter?
dave
Hobbsmeerkat
Re: Mini Tweeter
« Reply #4 on: 2 Oct 2022, 06:53 pm »
The Mini tweeters are pretty easy to disassemble, and you can use something soft to gently push it back out.
Just remove the four hex screws to remove the front plate from the motor structure. I've done it once before.
JCarney
Re: Mini Tweeter
« Reply #5 on: 2 Oct 2022, 09:45 pm »
I take her home from climbing class on Tues, so I'll take tools and do it then and report back. Thanks for the advice gentlemen.
Wish me luck,
JCarney
