I need some education on servo sub
0 Members and 1 Guest are viewing this topic. Read 907 times.
BrandonB
« on: 29 Sep 2022, 04:16 am »
I was checking out the subs on the website trying to envision how I am going to build my system.  Can someone please help me and explain what a few things are?
What is and what is the difference in a single ended RCA amp and an  XLR amp?
What is a standard hole and F hole amplifier box?
What is a neutrik speaker connector?
What are the difference in woofer orientation?  Why would I choose one over the other?
Hobbsmeerkat
Re: I need some education on servo sub
« Reply #1 on: 29 Sep 2022, 04:23 pm »
1. They are the same amplifier, but only the difference is the primary input connector being either RCA or XLR. (XLR amps are not currently available with no timeframe on future availability)
2. The F-hole is simply a cut out on the amplifier like you would see on a violin or cello, it's just a decorative option
3. The Neutrik connector allows you to be able to disconnect the amplifier from the woofers using single connectors. It has no bearing on performance
4. There is no audible difference in performance.  The dual opposing option is slightly shorter, and a little more physically balanced since the eight is distributed more evenly.
 most people choose the dual forward for looks more than anything.
Vince in TX
« Reply #2 on: 5 Oct 2022, 06:29 pm »
I definitely preferred the look of dual-forward.  They mesh nicely with the coverless X-Statics.    :thumb:
