Introduction
0 Members and 1 Guest are viewing this topic. Read 811 times.
AdamP
Introduction
« on: 23 Sep 2022, 04:16 pm »
Located in the UK. Been into stereo since "birth". Been though many phases in the past 40 odd years.
Current setup is:
Audio Note OTO Phono SE Signature
Origin Live Resolution + Illustrious arm + Hana ML
Audio Note S2 SUT
Linn Klimax DSM renew
Omega Super 3i on Dynaudio stands filled with (a lot of) Atacama Atabytes
STAX SR-L300 + SRM 252S
All interconnects are Audio Note AN-Vx, except on the STAX.
SATX SR-L300 have the thicker L700 pads (makes a lot of difference). SRM 252-S uses a proper regulated power supply (not a wall wart) with a sliver DC power cable.
All Power cables are Audio Note Lexus with MS HD Power silver plated plugs and IECs.
Speaker cables are Audio Note Lexus.
Re: Introduction
« Reply #1 on: 23 Sep 2022, 06:19 pm »
Welcome tô AC :thumb:
Seems you have registered two accounts.
« Last Edit: 24 Sep 2022, 04:03 am by FullRangeMan »
Re: Introduction
« Reply #2 on: 23 Sep 2022, 06:27 pm »
Current setup is:
Audio Note S2 SUT
Phil A
Re: Introduction
« Reply #3 on: 23 Sep 2022, 06:37 pm »
Welcome!
Re: Introduction
« Reply #4 on: 23 Sep 2022, 06:49 pm »
Cheers & Welcome to AC AdamP   :thumb:
Re: Introduction
« Reply #5 on: 24 Sep 2022, 04:02 am »
Hi Adam,
Your second account nameyahoo com was closed.
Please use only the AdamP account.
AdamP
Re: Introduction
« Reply #6 on: 27 Sep 2022, 12:50 pm »
I realised my email address would be showing as my user name so thanks for shutting that one down.
Just need a few more posts then I can search.......
Re: Introduction
« Reply #7 on: 27 Sep 2022, 10:09 pm »
 :thumb:
