DIY "Mega Monitors"
0 Members and 1 Guest are viewing this topic. Read 1557 times.
Early B.
DIY "Mega Monitors"
« on: 19 Sep 2022, 08:16 pm »
Just wanted to share my recent DIY speaker build dubbed the “Mega Monitors.” I’m posting in the GR Research circle because Danny designed and assembled the crossover. Plus, I’m using his servo subs.
The primary design goals were:
1.  high sensitivity
2.  a high level of dynamics with a superior mid-bass punch
3. a big sound with a high fun factor that can only come from large drivers
I went the DIY route because I couldn't find what I was looking for (at a reasonable price, of course). I also wanted to experiment with horns, but not the cheap plastic ones. The solid walnut horn was custom designed by Joseph Crowe for the Radian 475 beryllium compression driver. The 12” SB Audience mid-woofer is housed in a sealed cabinet with black Formica and solid cherry baffles crafted by Killian Smith of Denton Woodworkers. The spikes are from Daedalus Audio.
These speakers are 95 dB. I don’t know how low they go, but I’m guessing somewhere in the 70Hz – 80Hz range. Danny would cringe at this, but for convenience, I added binding posts on the top of the cabinet to connect the compression driver.  Tube connectors are on the back.
These speakers sound stunning. Gorgeous, pinpoint vocals. Crazy clarity. It’s the first time I’ve said to myself, “I’m hearing what the sound engineer wanted to convey.” In fact, they sound better than what I thought my system could achieve. I’ll stop there – you get the point.
Oh, I need to say this – I do NOT recommend designing your own speaker if you’re like me and have no idea what you’re doing. I took a high risk. Designing speakers seems simple, but don’t fool yourself. It ain’t cheap and you can forget about resale value. I’m guessing if these speakers were sold via an online dealer, they’d have to charge at least $12K. Plus, you need plenty of patience. It took 7 months from start to finish.
Is this my last commissioned speaker build? Nah. Maybe someday I’ll build the “Ultra Mega Monitors” with huge mid-bass horns like Avantgarde Acoustics or Odeon Audio.
EdwardT
Re: DIY "Mega Monitors"
« Reply #1 on: 19 Sep 2022, 09:39 pm »
Oh man, wooden horns…
tull skull
  • I can't send hare in search of anything!
« Reply #2 on: 19 Sep 2022, 09:45 pm »
Those look great. I always seem to get a "seriousness" attached to separate cabinet designs. Are you only getting to 80hz with the subs? What would you attribute that to?
Thanks again for sharing.
Early B.
« Reply #3 on: 19 Sep 2022, 11:08 pm »
These are servo subs, so they're designed to play much higher than 80Hz.
« Reply #4 on: 19 Sep 2022, 11:14 pm »
Years ago I have made a inexpensive Bass Reflex project for a client with the Beyma 12K200 99dB and the companion tweeter T2030, the xover was 5.2uF and
0.33mH, today they have nice coaxial drivers.
https://www.beyma.com/speakers/Fichas_Tecnicas/beyma-speakers-data-sheet-dome-tweeter-T2030.pdf
« Reply #5 on: 19 Sep 2022, 11:57 pm »
Early B, those are beautiful.  Bravo, very well done!
And I agree with you about what makes this type of speaker special - dynamics!  I won't even consider a speaker nowadays with a midrange smaller than 12 inches (and appropriately matching tweeter).  There's a liveliness to these types of speakers that makes other systems sound a bit dull.
poseidonsvoice
    • 2 channel/7 channel setup
« Reply #6 on: 20 Sep 2022, 10:08 am »
+1.
Best,
Anand.
Jaytor
« Reply #7 on: 20 Sep 2022, 02:12 pm »
Very nicely done!
corndog71
  • Some people call me Rob.
« Reply #8 on: 20 Sep 2022, 02:59 pm »
Sometimes I wish those old Super V coax drivers were still available.  It would be fun to swap out my Super 7 monitor tops on occasion.
