***SOLD***: Audiokinesis Azel Speakers
0 Members and 1 Guest are viewing this topic. Read 572 times.
Early B.
« on: 18 Sep 2022, 06:50 pm »
***SOLD***
For sale is a pair of Audiokinesis Azel stand mount speakers in satin natural walnut in 8/10 condition.
With a 12-inch mid-woofer, the Azels excel at dynamics and provide a much fuller sound than typical monitors. The Radian compression driver provides all the detail and shimmer of the cymbal, bells, etc. one would hope for. The midrange is better than expected from a 12" Eminence woofer. The greater ambiance is provided by a rear-firing compression driver.
These speakers offer a backstage pass to a whole new immersive experience. The overall sound is "dreamy and creamy." The main improvements are the dynamics and the fullness of sound. Piano sustains are longer and music flutters higher in space.
Let’s face it – most music is dynamic. A tiny 6" midrange on a 2-way monitor won’t be dynamic – that’s just physics. To get dynamics and scale, you gotta go big. With the Audiokinesis Azels, music is a lot more fun to listen to because they provide the “wow!” factor, and that’s what matters most.
Specs:
Mid-Woofer: Eminence Definimax 4012HO, 4-inch voice coil, 12-inch diameter, 22.3 lbs (USA)
Compression Driver:  Radian (USA)
Ports: two 3” diameter rear-firing behind mid-bass to increase midrange reverberant field, dual flares, tunable via one airtight plug (included) per port
Wave Guide: SEOS/super elliptical oblate spheroid 15.5 inches wide
Bass Cutoff: estimate 60 Hz, tunable via one airtight plug (included) per port
Voltage Sensitivity: 94 dB @ 2.83V @ 1M @ 8 ohm
Dimensions HWD: 24 x 18 x 12.5 inches, 4.5 inch wide 45-degree rear vertical corners
Net Weight: 72 lbs
Power Handling/Maximum Output: 100Wrms yields 114 dB w/only 1 dB dynamic compression
Input Impedance: 8-ohm nominal/6-ohm minimum, benign phase angle
The price is $1,600 plus actual shipping to the lower 48 only. Note that shipping weight will be approximately 85 pounds per speaker, so shipping charges will reflect the size and weight.
« Last Edit: 19 Sep 2022, 12:39 am by Early B. »
Will2
Re: ***SOLD***: Audiokinesis Azel Speakers
« Reply #1 on: 19 Sep 2022, 10:52 am »
WOW ..... that was a super-quick sale.
Great to see Duke's speakers getting the love that they deserve.  The buyer got a fantastic set of speakers for an incredible value.
