FS: Audio Note Kits L3 preamp and L3 Phono
0 Members and 1 Guest are viewing this topic. Read 889 times.
peckjed
« on: 16 Sep 2022, 10:26 pm »
Audio Note kits L3 Preamp - $2000
I am the second owner - I have upgraded the volume to a Khozmo stepped remote controlled volume and because of that have a smoked faceplate. The unit was built by Digital Pete, the remote attenuator was added by me. I will include the original Attenuator as well.
Info from previous owner about the L3 Preamp: Audio Note Kits L3 tube preamplifier professionally built by DigitalPete. Audio Note is the authority in high end audio kit equipment. This unit features many design upgrades including balanced XLR outputs, Khozmo stepped attenuator (volume control), Dueland capacitors (X2), and new old stock (NOS) tubes in addition to the stock tubes provided. The preamplifier incorporates two 5687-line stage tubes as well as power supply tubes. Standard build features include: I/E Core output transformers, Audio Note tin foil film signal capacitors, Beyschlag resistors, Audio Note AN-A shielded cable, PTFE silver plated copper wire and M2 Power Supply. This is an extremely well-designed preamplifier with incredible sound and spatial nuance. The unit provides outstanding high frequency reproduction and detailed bass response. This is an extraordinary opportunity when you compare other units of similar build quality
Audio Note kits L3 Phono- $1000
I am the second owner for this as well which was built by Audio Note Kits. It was the older 12ay7 model, which I went through ANK to order the upgraded board to convert it to the 12ax7/6922 model.
The preamp and phono sound excellent. Local pickup in CT or surrounding areas.
My images arent uploading here so they can be seen in my add here: https://www.usaudiomart.com/details/649898379-audio-note-kits-l3-preamp-and-l3-phono/
