Auto EQ calibration Microphone
0 Members and 1 Guest are viewing this topic. Read 1837 times.
jymy
« on: 15 Sep 2022, 09:10 am »
Hello,
I own a HD-AVA and intrested to try the Auto EQ to calibrate my speakers. I bought my nuprime second hand hand got it without the microphone. Do anyone know where i can purchase a microphone? or can use some other brand?
/Simon
rustydoglim
    • www.nuprimeaudio.com
Re: Auto EQ calibration Microphone
« Reply #1 on: 15 Sep 2022, 02:22 pm »
Don't bother, the auto-calibration function doesn't work as well as manual calibration. You can easily measure the distance from the speakers to the sitting position.
jymy
« Reply #2 on: 20 Sep 2022, 07:53 am »
Thanks for the advice, i only have 2 front speakers and a subwoofer and wanted the microphone for setting distances so the speakers and woofer would be in phase. But did it manualy, put distance to 0.00m for every speaker and then started to change subwoofer distance and finaly got them to play at unison. Pretty easy with the nuprime because you hear the change for every 0.01 distance right away. Now i can enjoy strong clear sound without booming bass.
Thanks again!
/Simon
