Selector switch on Jolida amp causing RT channel to cut out?
0 Members and 1 Guest are viewing this topic. Read 1038 times.
Parnelli777
I'm using a Jolida SJ 801 integrated and recently when switching from AUX to CD, right channel only cuts out intermittently. If I press gently inwards on the selector knob, it usually stops. It only affects the right channel so far.
Is this a bad, or going bad, selector switch? Recommended replacement switch?
Re: Selector switch on Jolida amp causing RT channel to cut
« Reply #1 on: 12 Apr 2005, 04:08 pm »
Quote from: Parnelli777
Sure sounds like it. It is possible a solder connection could be bad, but my guess is the switch.
Can you see the switch contacts? If so, you could try spray cleaning it and see if it is just dirt or oxidation causing the problem.
