X-CS Crossover
0 Members and 1 Guest are viewing this topic. Read 902 times.
brian.boyles
X-CS Crossover
« on: 9 Sep 2022, 04:33 am »
Anyone have any pictures of how they laid out their X-CS crossover?  It's my first time assembling crossovers (but not my first time soldering).
I just cant seem to work out how the fully upgraded components would fit on the little board that came with the flat pack.  Its smaller than the X-LS crossover board and the components are bigger.  May just need a bigger board.  But any layout pics or advice would be appreciated.
Danny Richie
    • http://www.gr-research.com
Re: X-CS Crossover
« Reply #1 on: 10 Sep 2022, 10:32 pm »
I don't have photo's of an assembled crossover. However, the X-LS Encore crossover is similar and we shot five videos on that one including crossover assembly.
E-Zee
    • Diy speaker resources and crossover assembly services
Re: X-CS Crossover
« Reply #2 on: 10 Sep 2022, 10:55 pm »
Here's a few photos for you.  Good timing.  I just happened to have this on the table, about to solder it up to ship out on Monday.  It's not yet soldered but you can see each of the connections.  As always their are many correct ways you can do the layout.  This is on a 5" x 7" board.
Good luck and enjoy.
Elon
[email protected]
« Last Edit: 4 Feb 2025, 06:03 pm by E-Zee »
E-Zee
Re: X-CS Crossover
« Reply #3 on: 10 Sep 2022, 11:31 pm »
X-LS crossover as comparison, same owner as the above X-CS, also waiting for final solder.   This layout is admittedly a little more complex than it needs to be but i like it clean and orderly so i often spend a little more time on layout design.  Owner added miflex bypass on both tweeter caps, which are ironically much larger than the caps they are bypassing.
brian.boyles
Re: X-CS Crossover
« Reply #4 on: 12 Sep 2022, 04:42 am »
Perfect !  Thank you both!
brian.boyles
Re: X-CS Crossover
« Reply #5 on: 12 Sep 2022, 04:43 am »
Thanks Danny.  Just built my X-LS crossovers this evening using those videos.  Very helpful, thank you!
