SOLD: Von Schweikert Audio TS-150 Surround Speakers Diploe/Monopole
0 Members and 1 Guest are viewing this topic. Read 779 times.
Jenner
Selling a Pair of TS-150s.
Asking $600 $450 plus paypal fees + actual shipping cost to your zip.
Box is 37lbs 18x15x15" shipping from 06483 if you wish to estimate the cost yourself.
I am the original owner. Smoke free pet free house.
Relatively rare as the are no longer made or available. Whenever I looked for another set for sale to go from 5.1 to 7.1 and I was never able to find one that wasn't already sold.
Original box and manuals included.
Dipole/monopole selection switch, see which works best for your room and movies.
PDF of the manual can be found here:
https://manualmachine.com/vonschweikert/ts150/2355877-owners-manual/
Woofers: Two-5.5" bass-mids per speaker, using mica-impregnated cellulose cones to reduce flexing and distortion for maximum bass impact and highest level of transparency in the midrange.
Tweeters: Two-1" tweeters per speaker, using fabric domes laminated with two layers of synthetic vinyl for strength and Ferrofluid liquid cooling for high power safety. Both drivers use our Low Distortion Motor to enable high volume levels to be reproduced without harshness or glare.
Crossover: Our proprietary Global Axis Differential Network enables either in-phase (monopole) or out-of-phase (dipole null) radiation patterns. Crossover point is 2.2 kHz. High quality air core inductors and polypropylene film capacitors are used to ensure very high transparency.
Power Handling: 200 watts nominal input (music power).
Frequency Response: 40Hz to 25kHz +/- 3dB, (60Hz to 20kHz +/- 1.5dB).
Sensitivity: 90dB @ one watt/one meter, 6 ohm nominal impedance (8 ohms compatible).
Size and Weight: 11.5"W(rear) x 3.5"W (front) x 11.5"H x 7"D. 16 lbs raw, 37lbs packed.
« Last Edit: 16 Jan 2023, 09:00 pm by Jenner »
edoggrc51
Jenner
Sorry updated with price thank you!
Jenner
« Last Edit: 16 Jan 2023, 08:49 pm by Jenner »
