A New X-CS Encore Drawing
0 Members and 1 Guest are viewing this topic. Read 696 times.
W.Scheffer
« on: 3 Sep 2022, 03:23 pm »
I just finished a new CAD drawing of the X-CS Encore that shows a cut away of the internal bracing.  I think this will produce a very stiff box that should be easy to control the resonance.  Along with No-Rez, it should be very quiet.
I plan on making three of these to be used as a left and right stereo pair and one for a center channel.  I have a set of X-LS Encores on the way from Danny now.
I would be interested in feedback from the forum.
Peter J
  • Hmmmm
Re: A New X-CS Encore Drawing
« Reply #1 on: 3 Sep 2022, 05:52 pm »
I don't think you can make a box too stiff, and I think tying the baffle into the bracing structure is a good idea as well. My only caution would be to not change volume of box significantly.
