How does a miniplug to toslink adaptor work???
0 Members and 1 Guest are viewing this topic. Read 1380 times.
Tonto Yoder
« on: 11 Apr 2005, 09:04 pm »
Got a new computer (with Brad's advice) with internal speakers, but with a minijack on the back for external audio connection.  Right now I'm using the typical miniplug to miniplug cable to connect to some powered computer speakers, but supposedly I can use a fiber optic digital cable if it has a miniplug connector.
How's that work??? All the optical cables I've had before were strictly toslink.  (I ended up buying a discontinued adapter from Radio Shack: toslink jack to miniplug).
Brad
« Reply #1 on: 11 Apr 2005, 09:12 pm »
I think Apple is using the same connector on the iMac G5 that they use on the Airport Express.
They are selling a 'connection kit' for the AE that includes the mini-Toslink cable.  I'm sure that cable is available elsewhere for less money though.
There was a post here a while back by audioengr who had taken an AE apart, discussing the dual function of the port.
audioengr
« Reply #2 on: 12 Apr 2005, 12:38 am »
There is an adapter that you can use that brings-out the Toslink connector so you can use standard cables.  I have a mess of them.  Send me a postage-paid return envelope and I will send you one.
Tonto Yoder
« Reply #3 on: 12 Apr 2005, 11:03 pm »
Thanks Steve!!!
It WILL be cryogenically treated and have Bybees inside????? :lol:
John Ashman
    • http://forum.adnm.com
« Reply #4 on: 13 Apr 2005, 02:45 am »
Is there a "breakout" cable that allows  you to hook up analog and optical simultaneously?  That would be a tricky adaptor to make, I suppose.
audioengr
« Reply #5 on: 14 Apr 2005, 03:43 am »
Quote from: John Ashman
It would have to be designed and added.  It requires two separate drivers.
Tonto Yoder
« Reply #6 on: 15 Apr 2005, 01:52 pm »
Quote from: Brad
Their kit is $39 and seems to be by Monster Cable. It includes two options:
a cable for the optical connection AND a cable with mini-plug to RCA's.
Essentially, one is paying for one cable he won't use, so it might be better  to decide between Toslink and RCA and devote $$ to just THAT cable.
John Ashman
« Reply #7 on: 15 Apr 2005, 02:57 pm »
The optical cable for this is about a $10 cable at most.
jholtz
Optical to RCA convertor?
« Reply #8 on: 28 Apr 2005, 02:00 am »
I happened to read your post and wondered if this is an optical to RCA convertor? I'd love to buy one of those that wouldn't destroy the sound.
Jim
Quote from: audioengr
