Monolithic PA-1 + subwoofer?
0 Members and 1 Guest are viewing this topic. Read 1782 times.
T. Perinne
« on: 11 Apr 2005, 09:01 pm »
I like the the Monolithic PA-1 for a two channel system but was wondering how/if a powered subwoofer could be correctly incorporated.  Would a different preamp altogether with seperate subwoofer channel be needed instead?  I'm trying to stay with something nice and tidy like the PA-1.
WEEZ
« Reply #1 on: 11 Apr 2005, 09:35 pm »
I think the pre-amp has (2) outputs. I don't know if there are impedence issues or not , though.
WEEZ
CIAudio
« Reply #2 on: 11 Apr 2005, 09:43 pm »
On the PA-1, the 2nd pair of outputs can be used into a powered sub. The sub would need to have an electronic crossover which sums to mono, or you could use two powered subs in stereo :D
