SOLD PUA-12 Tonearm 12" / Gimbal Hi-End design 48 state ship $1100.00
0 Members and 1 Guest are viewing this topic. Read 489 times.
undertow
SOLD
PayPal Friend/Family payment ONLY – 48 state shipping included
Zorin Audio PUA-12 Tonearm 12” / Gimbal Hi-End design 48 state shipping included
PRICE - $1100.00
For sale is one of the most refined, and finest 12” tonearms designed in the past decade. It is all polished
stainless steel, and brass.
This Zorin is in Excellent shape, and will be shipped in original container / box with
all original hardware.
12” tonearms have 25% less distortion than 9” and 10” so its worth the update if you can mount
to your table. This uses a standard 3 bolt mount. Or shaft will likely just drop into any standard collar you already have mounted into your turntable.
This arm can adjust everything from Azimuth, VTA, VTF, SRA, Anti-Skate. There is nothing it cannot adjust that exists on a tonearm for any turntable setup.
ARM comes with the original Zorin Plexiglass Template so you can easily measure and drill or mount to any arm board, with perfect distance from the Spindle.
Zorin PUA-12 Specs :
DIN: Standard Universal DIN connection at base of arm for any cable available.
Type: Gimbal Bearing Tonearm
Effective length: 308mm
Overhang: 13mm
Offset angle: 17.6 degrees
Mounting distance: 295mm
Cartridge weight range: 5 to 20g
Vinyl Engine Link –
https://www.vinylengine.com/library/zorin-audio/pua-12.shtml
Analog Planet
https://www.analogplanet.com/content/zorin-music-tp-s3-turntable-taiwan
« Last Edit: 31 Aug 2022, 03:19 pm by undertow »
