NHT 3.3 Speakers (Massachusetts, 01529)
0 Members and 1 Guest are viewing this topic. Read 576 times.
esprits4s
« on: 27 Aug 2022, 06:43 am »
I am offering my NHT 3.3 speakers. These have the rare mahogany finish and are in excellent condition with the exception for the front baffle diffraction foam. The foam issue affects all NHT speakers from this era and it can be easily replaced. The factory footers and original boxes are included.
These are fantastic full-range  speakers that were considered fantastic values when released new. They remain exceptional speakers today. Most commonly found in black, the mahogany finish is quite rare, and this pair is in excellent condition.
Price is $1300. Local pickup is strongly preferred. The original boxes are included and are in very good condition, so the speakers could be shipped. However, they are large and heavy, so the buyer would need to make all shipping arrangements. I would be willing to drop them off, in the original boxes, at a shipping location if that helps.
Specs from the Stereophile review:
"Description: Four-way, sealed-enclosure, loudspeaker system. Drive-units: 12" polymer-cone woofer, 6.5" polymer-cone midbass, 4" polymer-cone upper midrange, 1" fluid-damped aluminum-dome tweeter. Crossover frequencies: 100Hz (12dB/octave), 320Hz (12dB/octave), 3.5kHz (18dB/octave). Frequency response: 23Hz-26kHz ±2dB (in-room, 1m). Usable bass response: -6dB at 19Hz, in-room (-3dB at 22Hz, in-room). Sensitivity: 87dB/2.83V/1m. Nominal impedance: 6 ohms (4.3 ohms minimum, 10.5 ohms maximum, no phase angle greater than ±30 degrees). Amplifier requirements: 30-300W, 1000W peak.
Dimensions: 42" H by 7" W by 31" D, not including grille or stabilizers. Weight: 123 lbs each."
esprits4s
Re: NHT 3.3 Speakers (Massachusetts, 01529)
« Reply #1 on: 29 Aug 2022, 04:38 pm »
Sale pending
