What could be my problem?
0 Members and 1 Guest are viewing this topic. Read 2758 times.
lovelexicon
« on: 25 Aug 2022, 04:36 am »
No change to my preamp (Parasound 7) and amps (Extreme Monos).  And no maintenance have been done to the monos for 19 1/2 years.
Lately I found myself kept having to turn up the volume knob on the preamp to obtain the same sound level---from 65db to 67db to 70db to 75db.
Is this an indication that my amps running out of juice?
uncola
Re: What could be my problem?
« Reply #1 on: 25 Aug 2022, 03:09 pm »
19 1/2 years really?  Amps might need to have caps replaced.
SJ David
« Reply #2 on: 25 Aug 2022, 03:25 pm »
Something else in the chain have variable volume control (DAC w/pre-out option), software-adjusted volume (DSP under ROON or similar) or are you listening a lot more to hi-rez sources (lower gain levels)?
timind
  • permanent vacation
« Reply #3 on: 25 Aug 2022, 04:58 pm »
When's the last time you had your hearing checked?
Bob2
« Reply #4 on: 25 Aug 2022, 10:48 pm »
Why not save some time and effort, call Klaus. He will know what the problem is and how to fix it.
SJ David
« Reply #5 on: 25 Aug 2022, 11:36 pm »
Maybe Klaus would be happy to help out but why assume it's his equipment that has an issue?
Bob2
« Reply #6 on: 26 Aug 2022, 10:32 am »
Why not start with Klaus? He knows the equipment better than anyone. Likely that the OP knows about other volume controls on his own equipment and software.
Ice10
  • Enjoy every sandwich
« Reply #7 on: 26 Aug 2022, 11:41 am »
Call Klaus. After nearly 20 years my $.02 is you need new caps. It’ll be a great time to do any upgrades as well while they’re in the masters hands. Only downside, I’d suggest making sure you have a back up amp if you listen to music with any regularity as you won’t see your amps for a while. That’s not a knock on Klaus, just the reality of a very busy guy with only two hands.
Things may have changed, but best time to call is after 8pm Klaus’ time.
