No longer available: Musician Pegasus R2R DAC Decoder DSD1024 PCM1536
0 Members and 1 Guest are viewing this topic. Read 546 times.
MT POCKETS
Original owner used in my second system. $895 Price includes shipping to lower 48 states and PayPal fee. OBM packing included. Wil only ship to USA.
Proprietary R2R + DSD structure
Really balanced 24BIT R2R + 6BIT DSD (32-step FIR )
Low noise power supply
FIFO buffer
Digital signal processing via FPGA
DSD1024, PCM1536 support USB and I2S input (Audio source must be compatible with the machine’s interface)
Proprietary USB audio solution through MCU based on STM32F446 advanced AMR
Thesycon USB driver licensed for Windows platform
No driver required on Mac and Linux
DSD
All inputs support DSD64-DoP
DSD1024 only support USB input
PCM
All inputs support 24bits/44.1, 48, 88.2, 96, 176.4, 192KHz
1536kHz for USB and I2S input
Sampling method
Original sampling rate/Sample rate exceeded
Digital input
Coaxialx1, via RCA
Optical fiber *1
USB*1
AES/EBU*1
I2S via HDMI LVDS*1
Analog output
RCA is 2.2Vrms
XLR is 3.55Vrms
Technical Parameters
Frequency response: 10Hz~60KHz
Total harmonic distortion plus noise: 0.002%
Signal to noise ratio: 123dB (A-weighted)
Resistance accuracy: 0.005%
Dynamic range:>120dB
AC power requirements: 110-240V voltage, 50/60Hz (Global voltage)
Weight: 3.9Kg
« Last Edit: 16 Aug 2022, 08:27 pm by MT POCKETS »
