Pedestale roller to spike switch problem
0 Members and 1 Guest are viewing this topic. Read 1076 times.
User456101
« on: 6 Aug 2022, 05:58 pm »
I got the Pedestales awhile back and am just trying to switch the rollers for spikes and I can’t get the roller off the insert. I think it is screwed into the insert that is mounted in the bottom of the speaker. The roller swivels and so it doesn’t unscrew from the insert. Anybody who owns a set of Pedestales faced this issue and solved it please let me know. I have tried to find the same insert so I could just remove the existing one with the roller attached and put a new insert in, and then screw the spikes into the new inserts, but I can’t seem to find the same exact insert online.
User456101
Re: Pedestale roller to spike switch problem
« Reply #1 on: 7 Aug 2022, 09:37 pm »
I figured it out.  I bought these threaded inserts for furniture and they fit correctly on the threads of the spikes, and also correctly into the holes where the casters+inserts came out (with thehttps://www.amazon.com/dp/B07GKFNHYF?psc=1&ref=ppx_yo2ov_dt_b_product_details
Danny Richie
« Reply #2 on: 8 Aug 2022, 09:50 pm »
Good deal.
