FS: Mofi Mobile Fidelity Ultradeck Turntable w/ Ultratracker Cartridge 35 hours
0 Members and 1 Guest are viewing this topic. Read 490 times.
dvzzz
I am selling great condition Mobile Fidelity Ultradeck turntable. Comes with an Ultratracker cartridge with 35 hours only on it, barely broken in. Everything works. Tonearm is smooth. I am getting out of vinyl. Factory double boxed for secure shipping. Feickert protractor is not included, I only added a picture to prove my ownership and that I indeed used it to check the alignment. Feickert is what Mofi uses for setup of all Ultradecks. $1750 + actual shipping is fair. New this deck is $2800.
TONEARM
Custom-developed and manufactured in the USA, the 10-inch Ultra tonearm uses smooth, high-quality ball bearings for low friction in the vertical and horizontal plane so all you hear is what is in the grooves. Cardas Audio wiring maintains signal purity from the headshell leads all the way through to the high-quality, gold-plated RCA connectors.
ISOLATED AC SYNCHRONOUS MOTOR
Our stepped-pulley AC motor provides excellent speed stability for pitch accuracy and rhythmic drive. The Delrin® pulley has two positions for 33 1/3 and 45 RPM speed selection. Motor vibrations are kept away from the platter and stylus by using advanced dampening materials that decouple the motor from the rest of the turntable.
CONSTRAINED LAYER DAMPENING
UltraDeck features three aluminum plates carefully bonded to an MDF body to add mass and eliminate tonal coloration, maintaining the true sound found on the record.
ANTI-VIBRATION FEET BY HRS
Any vibration of the stylus that is not created by the grooves in the record is a distortion that will mask musical detail. Developed in conjunction with the engineering team at Harmonic Resolution Systems, the world leader in vibration isolation for audio equipment, the included MoFi anti-vibration feet isolate your turntable from bad vibrations.
1.3-INCH DELRIN® PLATTER
UltraDeck features a massive 1.3-inch Delrin® platter. The increased mass creates blacker sonic backgrounds and a lower noise floor. Delrin® is a next-generation polymer developed by Dupont. In the world of audio, Delrin's® highly crystalline structure presents a wonderful impedance match to vinyl records, effectively grounding unwanted noise and keeping it away from the stylus.
HARDENED-STEEL INVERTED BEARING
Our hardened-steel inverted bearing system is designed for smooth, quiet rotational stability. The extremely low tolerance combination of steel, bronze, and sapphire—found in much more expensive turntables—will provide you many years of high-performance playback.
Includes:
Everything as it came from the factory. Doubleboxed.
Ultratracker cartridge.
RCA cable
Power cable
Hex keys for the tonearm
