SOLD Jolida Black Ice Fusion 6802 Integrated Tube Amplifier - Price Reduced
0 Members and 1 Guest are viewing this topic. Read 1058 times.
johzel
SOLD
-For Sale: Jolida/Black Ice Fusion 6802 Integrated Amplifier
- Asking $1195  REDUCED to $995 (Retail $2400)
-9/10 Condition – low hours
- One Owner
- The amp comes with the more expensive 6550 power tubes
- Remote and Manual included
- The amp is heavy – shipping weight approximately 60 pounds. Double boxed in original packaging. Buyer will need to pay for shipping costs (either FedEX or UPS) from 54406. Local Pick-up always an option. I will travel some distance for delivery. The box size is 24x19x15.
-Seller has 100% positive feedback on US Audio Mart, Audiogon and eBay
The Fusion 6802 is a remote controlled tube integrated amp that does 140
watts/ch of music power and is rated as either 60 or 70 watts continuous
depending on tube choice. It has a switch to go from EL34's to
6550/KT88/KT120/KT150's. These amps come with ESA clarity caps, Hexfred diodes, and Vishay resistors. The 6802 can run with 6550 tubes, EL34 tubes, KT88, KT120, or KT150 tubes. Jolida
kept all the well liked sound characteristics of the older 801 model
and improved the unit with a switch for easy interchange of tubes, lower noise,
increased clarity and a smooth presentation with midrange weight and
enhanced 3 dimensionality. The amps are unique in that they offer the best of EL-34's and 6550's with smooth midrange of EL34's with the excellent bass and high frequency extension of 6550's.
Dimensions: 18.25 inches (46.5 cm) wide by 13.5 inches (34.5 cm) deep by 8.5 inches (22 cm) high.
Weight: 53 pounds (24 Kg) net, approximately 57 pounds (26 Kg) packaged.
Multiple Inputs including XLR.
Front mounted selector switch-CD, DVD, Tuner and Aux. (for TV, VCR or Computer)
Features: Bypass or power amp setting, Switching from EL34 to 6550 tubes. Fixed and Variable out.
Custom Wound Audio Transformers with a core of
German grain oriented silicon steel. 15th generation proprietary design.
Secondary can be configured for a 4 ohm or 8 ohm load.
Top panel bias testing terminal with bias adjustment controls.
State of the Art Components: ALPS Blue audio potentiometer, gold plated RCA input jacks, ESA Clarity .47uF coupling capacitors, carbon grid resistors.
Low Feedback Design: Only 3 dB
Includes:
Integrated Amp
Remote Control
Manual
Original Packaging
« Last Edit: 18 Aug 2022, 01:16 am by johzel »
johzel
Price Reduced to $995
johzel
Still available.  Accepting reasonable offers.
