My first Tube Amp, 2a3
0 Members and 1 Guest are viewing this topic. Read 1265 times.
brad1138
  • Don't forget to dance.... Don't forget to smile.
« on: 26 Jul 2022, 03:27 am »
I had this amp built locally, with 12AT7s & JJ 2a3-40s, and other various fancy upgrades. It sounds great with my Moabs. I use an Odyssey Candela preamp, with RCA 12AU7 Clear tops.
This is likely replacing my Odyssey Kismet amp.
I just wanted to share  :D
rockadanny
Re: My first Tube Amp, 2a3
« Reply #1 on: 26 Jul 2022, 05:01 am »
Welcome to the 2A3 club!
Looks terrific. Bet it sounds great too.
borism
« Reply #2 on: 26 Jul 2022, 02:56 pm »
Welcome to AC!
Your 2A3 amp looks similar to my Bottlehead Stereomour under the hood. I wonder if your builder was Paul B?
brad1138
« Reply #3 on: 26 Jul 2022, 04:44 pm »
Welcome to AC!
Thank you,
It was designed by Brandon Wade and Paul, built by Brandon.
Paul seems to be quite well known.
« Last Edit: 26 Jul 2022, 06:52 pm by brad1138 »
coffeebush
« Reply #4 on: 2 Aug 2022, 09:15 pm »
If you do go down the diy route or have a tech build one for you, Matt at CascadeTubes.com designs diy amps and maintains a blog on progress. He helps with queries when he can. He did a couple of designs for 6sn7/300b about 10 years ago in a rather long thread on diyaudioprojects.com  — http://diyaudioprojects.com/Forum/viewtopic.php?f=9&t=2699&start=320&hilit=300b+monoblock. There are a few other builds too from another well known design on that forum. In 2019 I modified a eBay 300b I started out with and rewired to  one of Matt’s  designs, the one utilising both triodes of the 6sn7 per channel. Being unqualified I paid a guitar tech to inspect and test my work before first switch on when I first assembled the eBay version. Up until recently it has been playing everyday pretty much,  but now splitting time with a new amp of Matt’s design-a 12au7/6as7.
