Klipsch 600c upgrade Audyssey question
0 Members and 1 Guest are viewing this topic. Read 817 times.
owcraftsman
  • Less is more when God is in it.
« on: 20 Jul 2022, 12:05 am »
I finally finished my upgrades to 6000F's and 600C hooked them up and ran Audyssey.
The routine saw the 600s as reversed polarity and gave me the option to ignore so I did.
Is this normal or did I do something wrong. Below is the new network soldered. and I attached wires to speakers as indicated.
Full size image here
owcraftsman
Re: Klipsch 600c upgrade Audyssey question
« Reply #1 on: 22 Jul 2022, 11:09 am »
No Body?
Danny Richie
    • http://www.gr-research.com
« Reply #2 on: 22 Jul 2022, 09:52 pm »
They have a flipped tweeter polarity. You can ignore what Audyssey is telling you there.
owcraftsman
« Reply #3 on: 26 Jul 2022, 12:12 am »
Thanks Danny for the qualified answer, I figured as much because I knew it was flipped in the network that's why I clicked ignore. I just wanted to be sure, so thanks again. The upgrades sound great loving it so far.
