Rythmik Sealed Sub Build - Wiring Question
0 Members and 1 Guest are viewing this topic. Read 787 times.
MattSelinger
« on: 11 Jul 2022, 02:44 pm »
Guidance request:
I am in the process of building the Rythmik sealed sub. The Rythmik amp comes with female spade quick connectors.  Should I snip these off to instead make solder connections to the sub for both the amp wires and servo wires?
mlundy57
Re: Rythmik Sealed Sub Build - Wiring Question
« Reply #1 on: 11 Jul 2022, 02:57 pm »
Guidance request:
I snip those off, strip the wire back about an inch, twist the strands together then use the push button connectors on the drivers
JWCoffman
« Reply #2 on: 11 Jul 2022, 03:55 pm »
I soldered mine but Mike's suggestion is a good one.  I recommend securing the leads to the box and wrapping them in foam or similar.  I was a little sloppy with mine at first and had a lot of rattling inside the enclosure.
Enjoy, I'm very happy with mine.
MattSelinger
« Reply #3 on: 12 Jul 2022, 12:47 pm »
Much appreciation for the responses!!
Danny Richie
« Reply #4 on: 13 Jul 2022, 04:34 pm »
Go with what Mike Lundy said.
