budget phono stage with digital out - puffin and any other?
0 Members and 1 Guest are viewing this topic. Read 878 times.
JoseM
Hi everyone
Getting back into vinyl. Problem is I run a lxmini setup which I want to keep as digital in. It can accept analogue in but the SQ drops. The device is the minidsp pwrice-125.
It seems the puffin audio would fit the bill. That's actually the top of my budget. Would be grateful for any other alternatives I could look into.
Many thanks
Jay
artur9
Re: budget phono stage with digital out - puffin and any other?
« Reply #1 on: 10 Jul 2022, 03:13 am »
I have a Thorens MM-08 that does digital.
IIRC, there's a blog post on using any A/D from the phono and then using Audacity to apply the RIAA curve.
I think you're looking for realtime playback, not archiving and playing later?
JoseM
« Reply #2 on: 10 Jul 2022, 03:51 am »
Thanks Artur for the tip - that's a unit I was unaware of until now.
Yes - looking for real time playback.
rif
  • Not a cowboy
« Reply #3 on: 10 Jul 2022, 06:07 pm »
I have no experience with this phono stage, but it may suit your needs.  Do you already have a phonostage?  If so the art dio can do ADC as well as DAC, which i have experience with and can recommend.
https://www.parts-express.com/ART-USB-Phono-Plus-PS-Phono-Preamp-with-USB-Interface-245-8686
