SOLD!!! KEF KC62 Compact Powered Subwoofer (Carbon Black) - NEW UNOPENED!
0 Members and 1 Guest are viewing this topic. Read 387 times.
Bostown
  • BASS CLUB [Boston Audio Stereo & Social Club]
    • Second Time Sound - Audio Gear Re-Purposed
built-in 1,000-watt Class D amplifier (2 x 500 watts RMS)
dual 6-1/2" Uni-core force-canceling drivers
ultra-compact, acoustic suspension (sealed) cabinet design
frequency response: 11-200 Hz (±3 dB)
maximum output: 105 dB down to 11 Hz
5 room-placement EQ presets help you optimize your bass for its environment
Room, Wall, Corner, Cabinet, and Apartment modes
Music Integrity Engine uses several DSP algorithms to analyze the audio signal for deep, accurate bass
a wide range of controls and connections lets you customize your bass to suit your needs
variable low-pass crossover (40-140 Hz)
phase control switch (0°/180°)
line-level/LFE RCA and speaker-level inputs
line-level output with selectable high-pass filtering
independent volume control
connect to your system wirelessly with the optional KEF KW1 wireless subwoofer adapter kit (sold separately)
detachable power cord
10-1/16"W x 9-11/16"H x 9-3/4"D
weight: 30.9 lbs.
$1185 + shipping
« Last Edit: 14 Jul 2022, 07:08 pm by Bostown »
